88 mule 450 stuck in single wheel mode
By Jon Spruill
By Paul L
By rsar
By TjB
By Will D
Hello, I have a mule 4010 trans that appeared to overheat based on the temperature light on the dash and it went into limp mode. No steam though. After letting it cool and the next day, I drove it around quite a bit and it did not have any problems. Any ideas on this. Do thermostats work intermittently? I would like to fix the problem, looking for advice. Many thanks
