Bought this machine a couple years ago and the gages didn’t work.  I have troubleshot this thing numerous times to no avail. Thought it may be a common ground so I individually grounded  the gages, didn’t work.  I have tested the sending units.  All have some resistance that changes as the engine revs or gets warmer.  Please help me.  Thanks in advance
  • 4 months later...
I don't know if you've resolved your issue with the gauges since it's been a while.  Do the lights work on the gauges?  With the engine off, is the oil pressure warning light  and battery light illuminated?  When I turn on the ignition without startingt the engine, those two lights come on, gauge lights illuminate and the speedometer & tackometer cycles.  This applies to the Trooper and Renegade.  I can't address other Joyner products.  On my machine, all of the guages are powered by a 12vdc supply through a 7.5amp fuse.  There's a body wiring connector that may have come loose.  This connector passes the sensor signals to the gauges.  The speedometer and tacometer are run via the l/p connector (a different connector).  I have no idea where those connectors are located on the Renegades.
    • By SpaceGhost
      They will be coming off.
    • By redneckred
      I have a 2012 Bennche Bighorn 700X.  I bought it used.  It had been sitting in a field for several years untouched.  I put a new sun gear in the shifter, new shifter linkage due to the old one having been patched, and a new battery (and of course fresh fuel).  The machine cranked and ran beautifully.  I had it over a year and then the machine quit running.  As it would not stay cranked, I narrowed the problem down to a bad IAC valve.  I replaced it and it ran as good as new/old.  Fast forward, the machine started to act like reverse wasn't catching and would not always back up when in gear.  Then forward quit.  I assumed a bad CVT belt and got one.  Started removing the bolts from the cover and (3) just turn in the housing without coming loose.  (2) are on the bottom, so very little room to do anything with them.  I tried cranking the machine again to see the belt move since I can move the cover enough to see the belt and now the machine will not crank.  It turns over fine.  It gets gas to the injector and has spark.  I can spray cleaner down her throat and she would run until it ran out.  I have replaced the IAC twice and put a new injector with no change.  I went out and put the old injector back in to see if that made any difference and, well, it did.  I tried to crank the machine and the starter is stuck trying to turn the machine over even with the key off.  I have to disconnect the battery to stop it.  Before I shoot this thing, what am I missing?  Is this an ECM problem or something else I am not seeing?  Been dealing with these Gremlins for over a month now and weeds are starting to overtake the motor due to it not moving.  I would love to get the thing running first and any ideas of getting those CVT cover bolts out would be extremely helpful.  Thanks in advance.
    • By Kingfish
