I just recently traded for one. Its 4wd..all lights gauges work..dump bed. Seats need recovered..and it wont start. I found burned wire going to the fuel cell. It will run for a few seconds on starter fluid. If I decide trade or sell..what's it worth as is?
From what I read brand new they were $6400
As is?
Well ,sight unseen,  I would not pay over $2000 for one that I would have to work on once I bought it. If you fixed it, you can get more for it.
Bought a 2014 Massimo MSU500 in September 2019 for 1500 not running. The spark plug threads were stripped in the head and I was able to repair it without t taking the head off. It runs great now. Also replaced doors, light/horn switch assembly, and some other things totalling about 500. I am pleased with this purchase. I don't know if your 2010 has EFI or carb but sounds like your problem is fuel pump or fuse if its EFI. If its a carb it probably needs taken apart and cleaned. Good luck.
Quote
    • By SteveS
    • By rdborra
    • By Frank Mac67
      - NO CLICK - NO OTHER NOISE
      Can anyone help?
      Can anyone help with this?
    • By mcraigchr
      Howdy y'all,
      Craig C.
