2005 Polaris Ranger No Reverse
Mac
You'll have to follow that linkage,  physically follow it. Check the lever under the dash n stuff for obstruction, but mostly wherever it ends up.  To see that its clear, and operating properly.  Sometimes branches, and stuff can foul the linkage. Cables can break, or jam. But since yours is catching the forward gears, its probably not a broken cable. It could still be jammed. I'm always pulling branches out from underneath mine. But it all starts there. Where it goes into the transmission, or transfer case, or differential. Wherever it goes.  Make sure its operating the lever, or otherwise working properly. After that, it's mechanic territory. But you have to eliminate the simple stuff first.
Finally found the issue when we got the gear casing out and opened up, it would seem the reverse chain had snapped, resulting in no reverse.   After much swearing and cursing , and waiting for parts, the new chain, we finally had success.   I notice that the grinding sound, which seem to be a problem with a lot of the polarises especially in reverse has now gone.
Changing the chain was interesting as there was nothing on YouTube that tells you how to put the new chain on.  I had to remove both the bearing and the dog engagement face also the gear-33T, 6 face engagement, once you do this the chain will basically slip on into place, you have to do this, otherwise the chain will not go on.   There are some good videos on you Tube that you should watch before attempting to do this.   One last thing, check that the gears are engaging and in the right place before putting the gear case back into the body.
If I can answer questions regarding this please don't hesitate to drop me a line.
  • Thanks 1
  • 1 year later...
    • By camojay
      1400 miles on it
      20240817_133539_1.mp4
    • By weasel
    • By Brent4a
      2022 Axis 700 overheating. We bled system several times, no luck yet. Weird thing is Radiator isn't getting hot and air coming into overflow jug. Doesnt seem like its moving water. Fan working fine, even wired it to turn on by switch. Only has 100 miles or so, just baffled. I am going to try bleeding more and see what happens. I did the head gasket test for fumes in the antifreeze, that was neg so far... Thanks
    • By diamondjfarm
      Thanks.
    • By mac66
