  • Alex changed the title to 2018 Cub Cadet Challenger 750 shifting problems
You probably have too much grease in the primary clutch housing that has the weights. I had the same issue with mine. Over a cup of grease in there! The roller weights in there need to move and won’t if cold due to a cup of 90 weight gear oil. Manual calls for slightly greased with 90 wt oil. I live where it is very cold in the winter. I used moly dry spray instead of grease.
  • 11 months later...
YES!  The Cub Cadet Shifting is a poor design. I understand and sometimes forget that you must have your foot on the brke to shift, but, I is still a major pain, especially while plowing.  I hope they find a better way to shift or my next buggie won't be a CUB...
I have a 2020, when I first got it I WD40’d all the moving parts related to the shifter, even the plastic part that moves with the shift lever.
I've never had a problem since then and I’m thinking the dealers should do this before it’s delivered to a customer.
I Have a 2017 Challenger 550.  it is a piece of S*** it has 324 miles and 112 hours on it and is currently in the shop getting its 4th new clutch that is an average of about 28 hours per clutch.  this machine is not abused at all it is lightly used around the yard and was intended to plow my driveway but can't even use it for that since the clutch system does not allow you to back up any inclines without burning out the clutch and the shifting of this machine is pathetic,  I have been going back and forth with level 3 tech support and they seem to put the blame on me for user error everytime.  I was told today they i should never put the machine in a position where i would have to backup from a stop with any incline (LOL) you pay $15000 for this thing and you have to drive it on flat surfaces.  *********Buyers beware these things are junk**************
 I have I have the same your Cub Cadet 2018 Challenger 750 and I have new shift to put in it and all the new shifter is giving me problems and I found out that if you brake lightly you can go from low high and neutral and if you can't get a past neutral into reverse or Park, brake a little harder and it should go all the way up reverse and Park. Hopefully that helps you out. I took my old one apart and there's only two little pieces in there besides the shifter and a spring into little levers at hit notches.
  • 4 weeks later...
My 2017 750 has the same problems  550 miles 66 hours.  3 chutchs.  muffler broke. seat cracked. won't shift.  now the timing chain jump off recking cam gear and bending the yalves.  the timing chain  adjuster was assembled wrong right from the factory. Sent a video  of it to cub and cub will not help me out.  We have to get the word out to not  buy this junk.
  • 7 months later...
I have a 2022 challenger 750 and most of the time it will hardly go all the way into park and when shifting from park to reverse the gears grind. Sounds  horrible, but sometimes it's fine.
  • 5 months later...
I have a 2018 Challenger 750. I would occasionally have this same problem shifting but could always resolve within a half dozen attempts.
Today was different. After a short run, I was in Reverse, backing it towards the garage. I then went to put it in High to move forward and adjust my angle. While I was able to move it past Neutral and into Drive, the display still showed R. I tried changing gears again thinking it didn’t click into Drive right but when I moved to Low, High admin, and then Neutral, the display still showed a R. Next I put it into park and the display finally changed to P. Now I can’t get it out of Park. No matter what gear I move it to, the display shows P. It will not move no matter what gear I try.
Anyone seen this before or have suggestions? Thanks!
  • 1 year later...
Hello, I have. 2020 challenger 750 that’s stuck in drive. It has been bad since shortly after I got it. It gradually would get more difficult to shift until now it won’t shift. The button pushes in but won’t release. I only have about 150 miles on it and it hasn’t been a rough 150 either. Any ideas?
    • By hisun junk
    • By Jacob E freeman
    • By Dennis
    • By redneckred
      I have a 2012 Bennche Bighorn 700X.  I bought it used.  It had been sitting in a field for several years untouched.  I put a new sun gear in the shifter, new shifter linkage due to the old one having been patched, and a new battery (and of course fresh fuel).  The machine cranked and ran beautifully.  I had it over a year and then the machine quit running.  As it would not stay cranked, I narrowed the problem down to a bad IAC valve.  I replaced it and it ran as good as new/old.  Fast forward, the machine started to act like reverse wasn't catching and would not always back up when in gear.  Then forward quit.  I assumed a bad CVT belt and got one.  Started removing the bolts from the cover and (3) just turn in the housing without coming loose.  (2) are on the bottom, so very little room to do anything with them.  I tried cranking the machine again to see the belt move since I can move the cover enough to see the belt and now the machine will not crank.  It turns over fine.  It gets gas to the injector and has spark.  I can spray cleaner down her throat and she would run until it ran out.  I have replaced the IAC twice and put a new injector with no change.  I went out and put the old injector back in to see if that made any difference and, well, it did.  I tried to crank the machine and the starter is stuck trying to turn the machine over even with the key off.  I have to disconnect the battery to stop it.  Before I shoot this thing, what am I missing?  Is this an ECM problem or something else I am not seeing?  Been dealing with these Gremlins for over a month now and weeds are starting to overtake the motor due to it not moving.  I would love to get the thing running first and any ideas of getting those CVT cover bolts out would be extremely helpful.  Thanks in advance.
    • By Kingfish
