Massimo knight 500 no start
By weasel
By Jim Kessell
2005 American Landmaster
EH65 Subaru Robins
By Buddee
2010 Hisun 500 - Carbed'. She sat for about 3 weeks since last use. Couldn't get it started.... has spark but plug was not wet. Bought new plug, cleaned the carb, confirmed fuel pump (pulse type) is working. Still nothing. Put gas in the plug hole.... started right up and idled as normal and drove perfect. Used it for the rest of the day without issue. Tried to start again next morning.... same problem. Poured gas in plug hole again.... started up and best kind again.
By vachi
hi everyone i have this 2021 Hisun forge 250 that won't start. no spark no fuel. when i turn the key on i dont hear the relays click or fuel pump come on. it does have power but the relay doesnt ground the pump or the ignition coil. dont know if there are any safety switches on this model or not. it does crank and all the accessories work. i hot wired the pump and it does work. i found a wiring diagram but it's very hard to figure out and was hoping someone has seen this before. all fuses are good. thanks in advance.
By Robby
Hello, I have a 2013 500 utv hisun. Was running ok and cut out while parked. Bike will not start now. It turns over, but won't fire. I have no spark and no fuel. I replaced fuel pump, ignition coil, spark plug, cdi, voltage rectifier and all the fuses and relays. Could bad stater cause no fuel because I can't hear the fuel pump priming. Any info on where to start looking for problem.
