2013 Intimidator UTV ENGINE SWAP
I have a 2013 Intimidator with a 750 Kohler V2 engine. In the future I thought about swapping the engine with something that has more power.
Does anyone have experience with engine swaps? Also what about swapping it with a motorcycle engine. Mine has the CVT with a 2 speed transmission. This was the first edition of the Intimidator and they basically used a lawn mower engine, so it’s a loud and runs 30 mph tops.
  • Alex changed the title to 2013 Intimidator UTV ENGINE SWAP
    • By Jon V
    • By Goat Quilter
      We pout new belts cleaned engine and carburetor plugs you name it.  Drove down road no problem came back uphill no power won’t go . What’s the issue?
      could it be clutch?
    • By hisun junk
      I have a 2018 cub cadet challenger 750 with a broke chinese hisun motor and I know that I'm not alone! Almost all the places that were selling them in Colorado don't anymore due to the return for repairs on the clutches and broken timing chains! Don't have yours fixed because it will happen again! They just replace the broken parts with more junk chinese parts! I talked with a UTV mechanic that has replaced one person's clutch 4 times! I have people contacting cub cadet about these problems and also looking into complete motor replacement from hisun junk to a Japanese motor in which the chinese cloned their junk from.
    • By lmarkie
      Any thoughts?
    • By Goat Quilter
      New belts and engine cleaned and checked carburetor cleaned drove on flat ground fine turned to go up hill lost power wouldn’t go
      Could it be clutch issue??
      so frustrating this thing has been in shop more than used on our farm.
