I have a new, 2 week old, T-Boss 410 and with the differential locked, and also in reverse with or without diff locked, I am getting a metal-on-metal sound.  It still pulls fine in 4wd low, but definitely some substantial metal noise. I haven't actually checked the diff fluid, but there are definitely no leaks.
Thoughts?
Thank you
  • 4 weeks later...
My wife drove our Buck 400 around the neighborhood with the parking brake fully engaged, complained of rubber smell, completely burned it up.  Now if it's engaged at all, metal on metal sound.  Definitely a possibility.
    • By Mike Jenkins
    • By Karlibob
    • By Blair
    • By Xov
    • By mcraigchr
      Howdy y'all,
      Craig C.
