The rear differential has broken
By camojay
20240817_133539_1.mp4 Â Â
I’m need a couple parts. Diff. Lock Actuator mainly. But I would like to find a donor that maybe has bad motor or something along those lines.Â
if anyone has or knows of anything please holler at meÂ
thanks RandyÂ
By SayHiToRambo
08 trooper 1100
Bit of background. First the machine would take for ever to start. So I adjusted the valve shims into spec and made sure the timing is correct. Starts perfectly now.Â
Â
now it fluctuates on idle. Bogs down, Revs up, repeat. I noticed the fuel pressure drops from 60psi to 20psi while that happens. It also bogs down at the lower end of each gear, higher rpm seems to be fine. Seems to struggle under load. In neutral it revs up perfectly.Â
Â
brand new fuel pump, fuel filter, gas. I noticed on the fuel pressure regulator there’s that vacuum nipple, it’s not attached to anything and I’m not sure where it would go. Possibly the problem?Â
Â
Another issue is the tip off the end of the exhaust is broken off, sensor is still attached and connected. Could that cause these issues?Â
Â
my next plan was to look into the pressure regulator and voltage to fuel pump while driving. Is there anything I’m missing or any ideas you guys have?Â
Â
thanks!Â
By allinone
Recently purchased 2nd hand not going Crossfire GT400 (Australian branded name?) 2020 model. Has some issues what would be the best forum to pose questions.
