sway bar on a 2019 teryx 4
By FTG-05
By Robbie Wyre
I'm working on a 2005 Cub Cadet side by side and I'm trying to remove the front two axles. I have a slide hammer puller on the inner joint and with all my strength they will not budge. Anyone have the same issues and is there something I'm missing or a trick of some sort to pull these out? Any suggestions please and thank you.
By KimAC
-Kim
By Paul in Wisconsin
I have a 2023 Tracker 800SX LE that I want to add a sway bar to.
The service manual shows how to remove and reinstall the sway bar.
I called Cabela's to try and get the saw bar. They said they can't get one and the 800SX doesn't have one!!?? Then why is it listed in the service manual?? No answer from them.
Have any of you found a saw bar that fits and what did it cost?
By Qtband
I'm looking at picking up this UTV and this is what the owner says:
"All I know about it is it runs. Display does not work and it will not move! Front end or trans could be locked up. It moves some, but does not sound good."
My question is, what could the moving issue be, and how can I check it out when I look at it? I feel the price is right at $2000, but I'd like to know what I'm getting into.
