Hisun 800 UTV grinding going into gear.
By Edelbrock
Thoughts?
By Unhappy Kioti K9 Owner
I own a K9 with 50hrs that has been in for repair more than once the farm. Multitude of issues, trying to file lemon on it but interested in knowing if owners are organizing for a class action suit. The dealer informs me there are “a lot of owners very unhappy with these”.
By CSM_Retired
By ToughLuck
By Paul L
When I am driving at 30 to 40 mph on the highway, the display will change from H (high) to R (reverse). It does not actually shift into reverse, it seems to shift into neutral and starts losing speed and the gas pedal has no effect. After the rpm/speed drops for 5 seconds or so, it changes back to H and runs fine for another minute or so. You have to try to drive it at less than 5000 rpm or so, to try and keep this from happening. Any ideas on what the problem might be? It only happens at the higher speeds.
