American SportWorks LM 650 won’t start at times. Starter won’t engage the solenoid just “clicks” much like a weak battery would cause. Battery was replaced and problem went away and then came back. Replaced positive battery terminal. Problem resolved then returned. Replaced negative battery terminal. Problem gone then returned. Replaced the positive and negative battery cable ends. Problem resolved and now returned. The repair lasts for maybe 12 starts, then the solenoid just “clicks” again as it will with a weak battery. So I replaced the ignition switch. Problem solved for a week. With each “fix” the problem is resolved but only temporarily. Does anyone have any suggestions ? To replace the starter is expensive especially if it’s not the problem.
Sounds like a bad starter. The starter will land on low spot. Try tapping the starter body with a small hammer and see if it cranks when you get the solenoid just clicking. If it starts, the starter needs to be replaced.
Expand
Ditto
Make sure the starter is tight and the mounting points are clean. When it won't start pull the pull rope just enough to land on a different spot on the flywheel and then try to start with the starter. It could be a worn spot on the flywheel.
  • 2 months later...
@Travis Bad starter on an American LandMaster 650. “Finally “ found a starter. Subaru is out of the small engine business and replacement engine parts are scarce and expensive. Anyone ever  change a starter on an LM650? Can’t get on top mounting bolt. The service manual is no help and neither are shops in the area. Don’t want to just start removing hardware if it’s not necessary.
Installed the new starter on my LM650 with the Subaru engine. Removal was simple once the voltage regulator was removed. The starter would not engage all the time. Symptoms of a bad solenoid or bad starter. Subaru no longer is in the small engine business so locating a new started was difficult and expensive.  To my dismay, the new starter reacted the same. Here’s what I’ve done so far...replaced the ignition switch, the battery, the Battery cable ends, the battery post terminals, and now the starter with solenoid. I’ve cleaned or replaced any wire terminal dealing with the starter, ignition switch and battery. I have run out of ideas. The Subaru help line suggested the starter relay but that is part of the starter and the new starter covered that. The voltage regulator is the only thing not yet replaced but the dashboard digital volt meter indicates that it is working. Max voltage output is 14.25 volts and when the lights are turned on it drops to 12.5 volts. Does anyone have any suggestions ?
Yes, it has a neutral safety switch. If the Vehicle is not in neutral, the ignition is completely dead. My problem is not That. The starter attempts to engage the flywheel but cannot. It seems like it cannot roll the engine over. After several attempts it will succeed and the motor starts. As I stated previously, additional amps were applied and the starter engaged each time. The battery is brand new and charged. 450CCA capacity.
  • 2 months later...
  • 4 months later...
  • 5 months later...
Old post but, I would have tried a valve adjustment. Controls  the decompression when starting allowing it t o turn over. Depending on where engine stops, it could be hard to turn over.
  • 5 months later...
I had the same problem with the starter clicking at times on my LM 700 with a Subaru engine. I contacted technical support at Subaru and they sent me a wiring diagram that had a relay switch being installed between the starter and solenoid. I took this with the relay to my UTV mechanic and he installed it and it totally fixed the problem. This was a defect with the this engine that they knew about. I think this is why Landmaster went to Briggs. .. Fred
  • 8 months later...
  • 1 year later...
ke the wires from the starter and move to the solenoids and run wire from solenoid to starter. Watch a mfew youtubes on installing a 12v solenoid and it should be clear. Don't get confused with re;ay. The solenoid becomes your relay. Chaep fix.
    • By Gorj
    • By Jim Kessell
      Hi All
      2010 653cc
      Need any information on a Subaru Robins EH65 engine. Particularly the carb vacuum line to the bottom of the carb. I think it’s disconnected internally in the engine.
      Thanks Jim
    • By tuell
      Hi everyone I have a 2016 hisun vector 550 with 1320 miles on it I recently replaced the clutch the bell the belt the one way bearing basically everything inside the primary and drove approximately one mile my side by side just stopped pulling... no noise no smoke nothing the belt is still good but it's like the transmission will not engage in any gear any help would be greatly appreciated.... I have lifted the rear end and started the side to side put it in gear Wheels do not move but you can turn them by hand
