Take off the carburetor (unless  it's fuel injected)
And clean it, sounds like a clogged main jet.
Edit:
Okay, after reading. it's fuel injected.
I would try first running some injector cleaner in it, and change fuel filters and check for good flow.
    • By Pick a name
    • By Joe Breaux
    • By SteveS
    • By Flanman55
    • By Croppy38
