Need help choosing 16 Honda pioneer or 18 can am hd8!!
By Jon V
By Greg Kilgore
By Sisco
By Brent4a
2022 Axis 700 overheating. We bled system several times, no luck yet. Weird thing is Radiator isn't getting hot and air coming into overflow jug. Doesnt seem like its moving water. Fan working fine, even wired it to turn on by switch. Only has 100 miles or so, just baffled. I am going to try bleeding more and see what happens. I did the head gasket test for fumes in the antifreeze, that was neg so far... Thanks
By Mike-Tatum
I have a broken item I’m trying to find the name for so I can order a new one. The gas line goes to the fuel injector. What is the piece that attached the fuel line to the fuel injector; “Y” shape.
Mike
