    • By Roadstar515
      Regards, Rick
       up.
    • By Gorj
      I have had my E1 since late last summer and I have always noticed that the parking brake was weak or non existent. About a month or so after I purchased it I mentioned to the dealer that the parking brake did not function well. What I was expecting from the dealer, ' well bring it in and we will correct the issue.' What I got was the typical dealer response, "it may just need to be adjusted." No shit!  Well I finally decided to adjust it. A very simple process need only two 10mm wrenches.  Open the bed, remove the pin holding the bed  to the strut and move the bad out of the way. Right in front of the electric motor is a brake disk.  That is the parking brake. It has a small set of brake pads that are actuated by a lever attached to parking brake cable.  There are two 10 mm nuts on the shaft to moves the pads. Release the inner nut and hold it in place while screwing in the outer nut - that is really a bolt. After screwing it in about one turn, tighten the other nut.  Check the parking brake. If it is holding when activated, then you are good, but if not, then you may have to turn the bolt another turn. Do not turn to far or you will lock it up.
    • By SouthernGypsy
    • By Michigan sport.
      I'm sure many of you are aware of Michigan's emergency brake requirement.  I'm wondering if anyone has a good solution.
      Beyond paying the few fab places $$$$.. I'm curious is there another rear caliper with e brake style that would interchange with slight mods to  the Maverick sport rear mounting bracket?
