HISUN STRIKE 250 oil filter
TV1
  • 2 months later...
    • By JOSEPH LAMAR
      I have a 2020 axis 500 and I have replaced the TPS twice and the whole throttle body assembly once and still have code 122. I can barely drive the thing. It bucks and surges like crazy
    • By joynersfuntillitbreaks
      so i just picked up a 2008 1100 trooper and iv ordered a few parts for it now and 99% of what i got fits perfect my issue now is my rear wheel hub is stripped out got a new cv and it fits great but i order 2 different hubs from 2 different places now and they are both wrong the spline opening is to small to fit the factory cv shaft and yes the shaft factory part #s are the same paid 250 for an original new replacement if anyone has anything that works to replace the original hub please point me in the right direction
    • By Ridge Runner
      i have a 2019 Coleman 550 Outfitter.  The tail gate has a pin on each side, that snaps into latch blocks that are mounted on the inside of the tail gate opening.  There are two M6x16 pan head screws(bolts?) that hold the latch blocks in place.  The screws enter from inside the bed body, and I can’t figure out how to access them.  This is right by the tail light assemblies.  I tried taking a pan head screw out of the fender lip, but found out there is not a nut firmly inplace, to hold the pan head screw in.  Bottom line I’m making it worse.
      coleman was no help.  If I could figure out how they attached the tail light, then maybe I could put the latch screws in through the tail light hole.  Any ideas?
      thanks
      Ridgerunner
    • By camojay
