I have a land master  LM 400. Starts up just fine and idles fine but as soon as I run it for a little bit it seems to start sputtering so I pulled a choke out and it runs fine for a couple seconds and then I push the choke back in and it just shuts off. Any suggestions as to why?
Choking an engine provides a rich fuel mixture be lessening the amount of air entering the carburetor. So somewhere you have a fuel restriction, I would start by cleaning all fuel lines making sure the are clear of debris, if it has a fuel pump, be sure it works properly, and change the fuel filter.
If none of that works there's possibly a blocked jet in the carburetor that needs cleaned.
  • 5 weeks later...
Which engine? If it's the Robbin Subaru there is no fuel filter or fuel pump. It is basically a 9 hp lawn mower engine.  Sounds like the carb needs a good cleaning.
    • By BigWave
      Bigwave
    • By Mike Jenkins
