I have a 2015 Massimo 500 that idles really high and it will not let me shift into gear while it's idling. Not sure where to start. Also it will bog down and stall constantly. Starts right back up everytime. Advice please.
I don't know a whole lot about these Massimo brand, but it could be 2 things, a vacuum leak, causing excess air to enter the combustion chamber, or it could even be a electronic issue.
The bogging makes me think it's more of a vacuum leak, how I find vacuum leaks is I get a bottle of WD 40 in a trigger Pack, not a aresol can. And with it running spray around the injectors and lines and if I spray it in a certain spot and the engine speed changes, that's where it's leaking.
    • By CapnWalleye
    • By CapnWalleye
    • By Joe Breaux
    • By Bobbers
