Online Tire Vender?
By Greg Kilgore
By kadams428
Recently my four wheeler has had an issue of being set in gear and it begins riding on its own (up to 3-4MPH). It also is having difficulty shifting into different gears after riding in one gear (i.e. going from reverse to high gear). It will shift perfectly fine when shut off, but consistently has both issues stated above.
Previous research has shown me that it could be an issue with belt tension/deflection, however I have been unable to figure out how to do that with these machines. I've seen some clutches have a jam nut and all that is needed is a wrench and an Allen key to make adjustments, but I haven't seen/found that on the 600 clutches. Has anyone done this in the past or have knowledge of how to accomplish this?
By Ronald
Check engine light comes on after engine runs continuously for 5 minutes or so. I can shut down the engine and restart and check engine light goes out, then comes back on after running 5 minutes or so? What ya think?
By sxr951
