By amiracle40995
By Travis M
Just purchased a T-Boss 760 and before putting any miles on it I'm going over all the fluids, grease and problem areas that I've read about online because I know the factory quality control is garbage.
I've seen where everyone seems to have leaking axle seals after 2-300 miles on the T-Boss 550 and 760. I think I'm going to switch from the bellow-style diff breather to the automotive style diff breather that they use on my Tacoma and various other vehicles. I'll still keep it extended and infact run it even higher, probably into the air intake box, but I'm hoping this is what's causing the axle seal leak issue on these vehicles.
I'll do the modification and report back every couple hundred miles and let you know. I currently only have 8 miles, so it will be a few months before I find out if mine leaks like everyone elses.
By joynersfuntillitbreaks
By Mark Anderhalt
