Sometimes when I go from neutral to high, the machine will not move and I have to move the shift lever back and forth until it go into gear, and the strange part is when I go from reverse to high to low, it stays in reverse and I have to turn the machine off, move the shift lever a few times then I can start and take off in drive, please help.
  • 1 year later...
I have the same issue and cant figure it out. Did you have any luck fixing yours?
  • 1 year later...
I have a2009 xtz 1000 with the same problem what's the fix? Any help would be greatly appreciated thanks I'm in California and the closest dealer is 6hr. Drive
    • By Grant
    • By bms stallion owner
    • By SpaceGhost
    • By Bryan g
