WhiteLightning Posted March 16, 2020 #1 Posted March 16, 2020 Fixin to change the oil in my T-boss. Any tips or suggestions? This will be the first oil change. Thanks
Travis Posted March 17, 2020 #2 Posted March 17, 2020 Make sure you put the drain plug in before filling with fresh oil.
WhiteLightning Posted March 17, 2020 Author #3 Posted March 17, 2020 LOL Yep, I'll be sure to do that. 1
Locking Diff Posted May 27, 2020 #4 Posted May 27, 2020 Where is the oil filter on a Massimo T-Boss 410? Also oil drain is soooooo tight I can't get it loose, any suggestions?
WhiteLightning Posted May 28, 2020 Author #5 Posted May 28, 2020 I don't believe they have spin on oil filters. There is a strainer on the underside where the oil drain is.
Travis Posted May 28, 2020 #6 Posted May 28, 2020 My method for removing tight drain plugs is get a box end wrench, correct size, and a hammer. Put the wrench on the plug head, and hit the other end of the wrench with the hammer, it's basically like a Poor mans impact wrench. Be sure you are turning counter clockwise.
mseawell Posted May 29, 2020 #7 Posted May 29, 2020 I couldn't get the oil drain loose on my MSU 700 either. So I picked up one of those oil extractors. Remove the dip stick insert the tube all the way and pump to suck all the oil out. Never crawl under it to change the oil again!
Locking Diff Posted May 30, 2020 #8 Posted May 30, 2020 Thanks everybody, I emailed Massimo company about the oil filter. They replied and said would have technician mail me. The technetium must have forgot? I bought a oil extractor like somebody suggested. It kinda works, I couldn't get but a little less than a Quart of break-in oil out. So I just added enough to fill it. I figure if there is no oil filter what's the difference?
