Багги на воздух
BigTver
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By Will Sutton
      I've got a 2023 UT400 (bought from tractor supply) and I've been beating my head against a wall with it.
      It will start and idle perfectly. The second I touch the throttle it sputters and dies.
      I've checked that the fuel pump is working  (it is).
      I've replaced the injector, throttle position sensor, O2 sensor, and intake air sensor. All with no change.
      I've just taken a look a the schematic, and there is a crank position sensor as well.
      Could this be the source of my troubles? If so, where is this thing located? I can't seem to find it on any drawings from the parts suppliers.
    • By Hutch
    • By 2scoops
      I am in need of an IAC for my throttle body. I contacted JMC and they said I had to buy the whole throttle body for $209. I left a message at Joyner USA...they haven't called back. I found a Chinese company which have them for $17, but shipping is $32. With that I still have to hope it is the correct one which arrives.
      Does anyone happen to have one laying around they would sell?
      I understand a workaround would be to eliminate it and use the idle screw. I believe that would cause problems with cold start ups??? Elevation changes???
    • By owencole15
      Massimo 500 will only crank when I jump solenoid with screwdriver cranks right up and runs great. But won’t start with key doesn’t do anything when I turn the key. Only thing it does is power everything as in dash and fuel pump then have to jump solenoid to crank up and drive.
