I purchased my 2018 Cub Cadet 750 Challenger new in July 2019 and it will not go into 4 wheel drive.  Has this ever happened to anyone or do you have any idea as to what could be wrong?
  • Alex changed the title to 2018 Cub Cadet 750 Challenger won’t go into 4 wheel drive
  • 10 months later...
    • By CapnWalleye
    • By mcraigchr
      Howdy y'all,
      Craig C.
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
