Posted (edited)
I have a 2013 Massimo 400 that is sputtering at high speeds with the reverse, drive and temp light flashing.  When I start it in neutral, the neutral light will flash.  I believe it is an error code not sure though.  My apologies if there is a post already on this site.  I'm new at these forums.
Edited by Alex
Topic moved to Massimo forum. Title edited to include issue.
Usually the governor shouldn't make it sputter as the effect of it doing its job, it will just limit the RPMs.I
I would contact massimo with the flashing light to decode it.
It could be spark cutting out due to a faulty plug.
      Is there a diagram of all of the grease zerks for a Coleman UT 400?  Mine squeaks like crazy and want to try and remedy it.
    • By Rick A
