Getting a Mule soon once stop sale over.
Only issue I have is Mule is limited to 47 mph.
Most of my road around my place (before getting to off-road) is 40 mph.  However most people drive 50 mph.  I would like to be able to go 50 mph in the Mule for short distances (2-3 miles) while on the public roads.  I know the engine is more than capable since the same engine is in the Arctic Cat Prowler Crew and those are limited to 51 mph.  So what tune/piggyback is safe to add the 3-4 mph more top end I'm desiring?  Thanks
It probably is possible to get a few extra MPH. Of course, the engine may already be capable of doing 50+, you just need to take that rotational power and put it to the ground. Via transmission and centrifugal clutches..
But going over a limited speed is tough on a CVT system drive belt since it heats up fairly quickly when running at a sustained speed. And can cause cracking and overall premature wear.
I can also say for certain any modifications you do will most likely void the warranty.
    • By Pick a name
    • By SteveS
    • By rsar
    • By D MAYNARD
    • By TjB
