Massimo Buck 400 First oil change
Laveta
  • 4 weeks later...
On 5/1/2020 at 8:45 PM, kenfain said:
Can't help you with getting it loose.  But future oil changes would be much easier if you had a valve type drain.  I use the fumoto valve on all my vehicles when possible.  Makes oil changes extremely easy. No wrenches, just flip the lever.
Do you know what size to buy for the Buck 400?
Pull the existing drain plug, or an internet search will give you the size. Make sure there's clearance to install, for example, skid plate clearance. If extra length is needed to make the necessary clearance. Fumoto also has extension adapters.
I prefer the short nipple version. Don't forget to also get the hose end, that connects to the nipple. Fumoto sells reasonably priced tubing also. But you can get that locally if you prefer.
    • By Alex
      This is an interesting read. ADAS is main stream on cars these days. The technology looks to be headed towards UTVs and Off-Road Vehicles.
      Potential Motors and CFMOTO USA have announced a new partnership to integrate advanced driver-assist systems (ADAS) into recreational off-road vehicles for the first time.
      Sam Poirier, CEO and co-founder at Potential Motors, says the integration of its technology into CFMOTO’s vehicles will set new standards in the side-by-side segment. (Photo: Potential Motors Inc.) The partnership will first see Potential’s tech integrated into CFMOTO test vehicles. The companies will conduct extensive real-world testing at Potential’s purpose-built off-road proving ground in Fredericton, Canada, and CFMOTO facilities.
      Source: https://powersportsbusiness.com/top-stories/2023/12/19/cfmoto-and-potential-motors-announce-industry-first-adas-technology-for-ohvs/
    • By Goat Quilter
      We pout new belts cleaned engine and carburetor plugs you name it.  Drove down road no problem came back uphill no power won’t go . What’s the issue?
      could it be clutch?
    • By weasel
    • By Wesley
      I have a 2022 500 Hisun product, I have had them in the past. I change my oil myself and trying to drain through the hole where I remove the plug is a mess.  How does everyone keep the belly pan clean during the oil and filter service?
      Wes Jackson
    • By amiracle40995
      I've never seen the temperature go high on this thing. the fan runs almost all the time even though the sensor is  reading at the very bottom of it's range. ive taken the cylinder head off.  (nothing definitive but maybe a little fuel on top of piston with oil in it.i don't think this has anything to do with my problem )head gasket is 3 layers deep and I noticed some grit that might have been in between layers but nothing to say the head gasket wasn't intact.  black carbon build up on piston. I've looked all over the head for cracks from over heating. I'm about to look again for hairline cracks that are extremely difficult to see. my buddy helping me said to order rings in case they are letting oil pass thru he also said get a new head gasket.. I'm looking at water in oil first and I'm not ordering rings. I haven't checked the oil cooler to see if it's defective yet.  I'm just hoping someone had a similar problem. my only problem so far has been having to change the spark plug every 100 miles with 93 octane run thru it.
