I just purchased a 2015 strike 1000 and it won't engage into 4wd, along with that the cooling fans will not turn off. They run as long as they have enough battery to run. Any advice on how to get either one of those issues solved? Thank you
    • By Paul L
    • By Unhappy Kioti K9 Owner
    • By Dennis
    • By ToughLuck
