I'm really surprised HiSun doesn't make the manual available, as HiSun makes their own engines... I even looked on eBay for a paper copy, nothing.
The next best thing to do is contact Cub Cadet and see what they can do for you..
    • By hisun junk
    • By SouthernGypsy
    • By se3388
      Steve.............
    • By Jacob E freeman
    • By Gerald Mohs
