Only thing I could find was to do it every 800 hours.... No specifications.
On most small motors If I can't find the spec, I set them at .006" and have never had a problem .
Could also contact CubCadet/HiSun
For anyone looking for this information in the future I did find the Valve clearance specs for adjusting them.
Intake Valves-.08-.12mm
Exhaust Valves-.12-.15mm
Make sure you are at TDC when making the adjustments.
    • By CapnWalleye
    • By Joe Breaux
    • By Marie
    • By Steve Waldner
