Does this qualify?
By Michigan sport.
I'm sure many of you are aware of Michigan's emergency brake requirement. I'm wondering if anyone has a good solution.
Beyond paying the few fab places $$$$.. I'm curious is there another rear caliper with e brake style that would interchange with slight mods to the Maverick sport rear mounting bracket?
By Jon V
Good afternoon. When the timing chain came off its lower gear (previous owner had over-tightened the tensioner), I ordered new parts.. chain, oil-pump chain, tensioner etc.. But now that it's time to put it back together, the main crankshaft makes a clang noise and stops when you turn it by hand. I want to solve this before assembling everything. The camshaft cover is off so that the valves aren't being activated. Should the transmission be in neutral to turn the crankshaft? The engine was running fine until the chain came off the lower gear. Then it would spin when the starter motor engaged so I assumed the crankshaft was spinning. Any advice is appreciated.
By Farid
Hey there,
I’m trying to find a CVT (variator) for my Tracker Off Road 800SX Crew. Do you happen to have one, or know where I can get it?
Also, if you’ve got any other parts for this model, I’d love to hear about them!
Thanks a lot!
By Alex
Explore Kemimoto's CFMOTO accessories collection that will elevate your riding experience. From protective gear to performance upgrades, they offer everything you need to customize and optimize your CFMOTO vehicle. Kemimoto has bags, boxes, bumpers, covers, camera mounts, cup holders, doors, and more! Outfit your CFMOTO today!
18% off with code AFZ18 in August
By Retired Plumber
The rear differential lock light is on and I would like to get it off. How do I do that it is a Coleman UTV700.
