3010 valve spring question
GDS
I pulled the valve covers off the mule to adjust the valves. They have been tapping loudly. The two exhaust were correct but the 2 intakes were around .023. But the question is this As I was adjusting I found I could easy open the valve by lightly pressing. Should they should be stiffer than that?
no the spring tension sound about right...
    • By hetovi
      Hey everyone,
      I recently purchased a CFmoto ATV and I'm looking to add some accessories to enhance its performance and usability.
      I'm curious about what you all consider essential add-ons for a CFmoto.
      Specifically, I'm interested in accessories that improve comfort, storage, and overall ride experience.
      Are there any brands or products that you’ve found to work particularly well with CFmoto models?
      Any tips on where to get the best deals would also be appreciated. Looking forward to your suggestions and advice!
    • By mac66
    • By Mater Help
      I have a 2019 Bennche Warrior that I mostly use around my property for odd jobs. I also cruise the neighborhood and make short runs to the local pub and neighbors houses. The exhaust system is super loud. I was hoping to find something that will fit and work that is quieter. I have included a photo of the system that is on the unit now. Any ideas or recommendations?
      Second question: Recently, it has become hard to shift from park to any gear if the engine is running. The shifter moves fine if the engine is off. It is almost as if the clutch (no pedal) is not disengaging completely. I have not tried to do anything to correct the condition yet but as it gets increasingly more difficult, I need to do something.  Looking for a place to start. Nothing in the service manual that I can find.
      Any help will be greatly appreciated,
    • By Alex
      Explore Kemimoto's CFMOTO accessories collection that will elevate your riding experience. From protective gear to performance upgrades, they offer everything you need to customize and optimize your CFMOTO vehicle. Kemimoto has bags, boxes, bumpers, covers, camera mounts, cup holders, doors, and more! Outfit your CFMOTO today!
    • By sxr951
