I pulled the valve covers off the mule to adjust the valves. They have been tapping loudly. The two exhaust were correct but the 2 intakes were around .023. But the question is this As I was adjusting I found I could easy open the valve by lightly pressing. Should they should be stiffer than that?
no the spring tension sound about right...
2 hours ago, GDS said:
For the most part, yes and exhaust. At just under 3 bucks for OEM springs I have ordered a new set.
be careful of the rods they bend very easy, make sure there seated all the way.
    • By rsar
      Coleman UT 400 has a strong sulfur/emissions smell from exhaust all the time.  Kind of like it’s running rich and a catalytic converter is trying to make it run cleaner so it smells bad. Also misfires when warm. Idles fine. Full throttle fine. In between it cuts out. Do these have catalytic converters?  Almost acts like it might be clogged if so.
    • By TjB
    • By Will D
    • By rsar
