Hello all,  I have a yamaha rhino 660 with 156 hours on it. Just acquired it. It has anedelbrock carb and aftermarket exhaust. Anyone know how to adjust an edelbrock? Also, machine smokes like crazy. White smoke. So i need to get the carb sorted out and then see if its a bead gasket r valve guides causing the smoke I cannot find u h info online about the carb so any help is
muCh appreciated.
      Coleman UT 400 has a strong sulfur/emissions smell from exhaust all the time.  Kind of like it’s running rich and a catalytic converter is trying to make it run cleaner so it smells bad. Also misfires when warm. Idles fine. Full throttle fine. In between it cuts out. Do these have catalytic converters?  Almost acts like it might be clogged if so.
    • By SpaceGhost
