Hello all,  I have a yamaha rhino 660 with 156 hours on it. Just acquired it. It has anedelbrock carb and aftermarket exhaust. Anyone know how to adjust an edelbrock? Also, machine smokes like crazy. White smoke. So i need to get the carb sorted out and then see if its a bead gasket r valve guides causing the smoke I cannot find u h info online about the carb so any help is
muCh appreciated.
    • By SouthernGypsy
    • By JSwearer
    • By se3388
      Steve.............
    • By mark walkom
