I have a 2011 700 nordik with all new brakes and rotors and master cylinder. My problem is the back brakes are making a noise just like when brake pads and worn down to metal on metal.
  • 4 weeks later...
      Greetings All,
    • By SpaceGhost
    • By SayHiToRambo
      08 trooper 1100
      thanks!
