I am wanting to add a rearview mirror to my 2019 Mule Pro FXT. I am having difficulty determining the diameter of the crossmember on the ROPS where I would mount it. I need this information so I can order the correct clamp size. Can anyone provide me with this information? Thanks.
2-8, I don't have a FXT, but you can get a good idea if the tube diameter with a tape measure or ruler. Just lay either across the tube and try to sight the outer edges. If you had a dial caliper, you could get an exact measurement.  When I ordered the rear view for my 2020 mule sx, I found one from side by side atv. It came with several different plastic clamps for different size tubes. I still had to wrap the mounting area with some electrical tape to take up the slack but it works. On my '04 mule 550, I had a bolt on mirror so I drilled a hole in the top tube and got a longer mounting bolt and it works great.
Hope this helps,
Roger
Hope this helps,
Roger
Thank you so much for the reply.  One of my interests is shooting/reloading. Until you suggested it, I had not even considered using my dial caliper in this application.  Again, thanks!
    • By Xov
    • By Grant
    • By rsar
    • By TjB
