Looking for Commando 650 steering rack boots
By Fishing Wiskers
By Paul Angstadt
Paul
By diamondjfarm
Thanks.
By Joe Breaux
just an update on my MSU 500 . For all the misery it caused me the first 2 yrs, and the combination of some quality YAMAHA parts, it has now become a reliable ,useful UTV without the constant fear of having to push or tow it back from trails. I have not had a single issue pop up in a very long time.. FINALLY!....and as a side note, I just bought a C FORCE 600 ATV to replace an old and well used Honda that finally after 18 yrs gave up a rod bearing. So far the new one has really impressed me .. I like the new Power Steering and this CVT Auto Trans is new to me on an ATV .. I m used to constant shifting on my Hondas . It also has something I have never seen. Its EBS engine brake system, as soon as you let go of throttle, it engine brakes you to a stop rather quickly.. its great idea for the grandkids safety . Takes a little getting used to tho.. All in all, I like it. We shall see how durable it is after break-in.. I do "RIDE" them! .....and they honor their warrenty! and the dealer is 15 minutes away..
