I recently got a 2007 Commando 650 C4 and I'm in the process of going through it from stem to stern. The AZ sun has really taken it's toll on all the plastic and rubber. One CV boot is torn and the others are probably not far behind. Most of the rubber on the control cable ends are on bad shape and the steering rack boots are almost completely disintegrated. Anyone have a source for the steering rack boots?
    • By Jacob E freeman
    • By mark walkom
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
    • By Paul Angstadt
      Paul
