i have a 2007 3010 mule 950 diesel 4x4 it will drive but feels like something is binding then it feels like it brakes loose then will do it over again. at fist i thought it was a belt going bad  replaced it and it still is the same. could it be the front differential, transmission or rear differential and how do i find out which one it is
20 hours ago, Travis said:
I would start with something easy first, and check that your brakes aren't dragging. Jack it up, front and back and spin the tires.
I have a similar machine, and my wheels won't really spin when it's in the air. Not by hand anyway. Because you're also turning the differential.
But I agree that it needs to be jacked up, and on stands. That'll help pinpoint the problem wheel, or wheels.
Just be careful to make sure the wheels aren't spinning when you put it in, or shift gear.
    • By rsar
    • By D MAYNARD
    • By TjB
    • By Will D
    • By rsar
