i have a 2007 3010 mule 950 diesel 4x4 it will drive but feels like something is binding then it feels like it brakes loose then will do it over again. at fist i thought it was a belt going bad  replaced it and it still is the same. could it be the front differential, transmission or rear differential and how do i find out which one it is
20 hours ago, Travis said:
I would start with something easy first, and check that your brakes aren't dragging. Jack it up, front and back and spin the tires.
I have a similar machine, and my wheels won't really spin when it's in the air. Not by hand anyway. Because you're also turning the differential.
But I agree that it needs to be jacked up, and on stands. That'll help pinpoint the problem wheel, or wheels.
Just be careful to make sure the wheels aren't spinning when you put it in, or shift gear.
    • By Jacob E freeman
    • By Greg Kilgore
      This started back in the summer.
      While on a ride with the wife. Applied the foot brake and the pedal went to the floor. Thought the brake pads were gone. Ordered new pads. Removed the wheels to install new pads and they were in good shape.
      So I bled all 4 brakes cylinders. Got thin dirty fluid out. Almost like dirty water. No air. Got a good pedal.
      Then about a month later, same thing, brake pedal back on the floor. Could pump the pedal and get a little pedal back. Bled again and finally got a good pedal. The fluid was nasty like before. No air. And the fluid was topped off in the reservoir before I started the bleeding process.
      Now same thing. Pedal going back to the floor. Reservoir still full. I'm thinking the master cylinder is bypassing. So have a new on on the way and will report back.
      What do you guys think. Could it be something else.
      I used one of those hand operated vacuum pumps to pull the fluid out of the reservoir when I was bleeding before. First time I've used one. And after a small amount of fluid filled the catch bottle. Seemed like the vacuum pump quit working. Had to close the bleed screw. Pump the brake one time. The start the vacuum thing again.
      Again just wondering what you guys think. Using DOT 3 and DOT 4 brake fluid. Whatever I can get at a reasonable price at parts store.
    • By Kingfish
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
