I just bought a 2008 Trooper T2 not knowing much about them. On this one the owner said the horn doesn't work, the winch never did work and during inspection the rear brake lights didn't work. He said he replaced the rear light pods recently and the brake lights worked before. He said the fuse module is corroded so he bypassed it and rigged up his own switches for the fuel pump and radiator fan. I see in the wiring diagram the horn and rear brake lights are on the same circuit. Now I am worried the problem is in the wiring harness.
I have the wiring diagram from the online manual but I can't make any sense of it. I see lots of posts about wiring issues and I am feeling a bit overwhelmed with all the issues I see with these machines and am regretting buying it.
For now my main concern is to get the brake lights working so I can drive it to some nearby trails. I would appreciate any advice on how to go about diagnosing the problem or workarounds. Also if there is a better wiring diagram out there that might help. I would consider hiring someone local to diagnose it so any recommendations are welcome.
TIA.
Difficult to troubloeshoot from a distance.  The problem now is even if you found someone knowledgeable on your machine, the wiring mods the previous owner did will make it difficult to troubleshoot.   And off-brand rides mean we have to be our own mechanics.  Local support is rare.  Sounds like the person you bought your ride from tried to bypasss the problem areas instead of fixing them.  Has this ride been in deep water?  Corrosion usually occurs at the connectors.  Go through the whole machine and try to look for corrosion at the connectgors.  Check the brake light switch on the brake pedal to see if it is out of adjustment or a broken wire.  The winch control switch just pops out of the dash with a small flat blade screwdriver.  See if the connector came undone.  Also check the winch control relay.  I'll presume the winch motor is okay.  You might not be able to get a new fuse module, but I would try to clean the fuse connector as best as I could.  I think that's where most of your issues will be.  The brake light and horn should be on different fuses.  I don't know where you got your wiring diagram, but Joyner-USA.com has manuals for your machine.  I saw a post where the first 50 Troopers had a different signal flasher than the following units.  I don't know if there were any mid-year changes that would make troubleshooting your machine difficult.
http://joyner-usa.com/  may have the manuals you could use (free to download - pdf format)
Hi Dan,
Thank you for offering advice. I spoke to a friend who has RZRs and he recommended a local auto shop that he uses for electrical problems so I am taking it there tomorrow. If they can't figure it out I'll check on the things you suggest. The previous owner said he could get a new fuse box but you have to get a new wire harness too. I suspect it was expensive so he opted to do the bypasses. He only used it for hunting so maybe he didn't care about fixing it properly. Anyway will post the outcome.
Well I am so thrilled to find out the brake lights were working all along. The problem was they weren't shutting off because the pedal wasn't fully returning to close the switch. All along I thought I was seeing the running lights. A little cleaning and lube fixed the problem. Also the winch is now working. The battery tie down was touching the solenoid which caused it to short. A small modification fixed that problem. I feel so much better now that I know it wasn't the wire harness. Next is to get a shim kit for the sloppy steering.
The original owner mentioned there is a shim kit to take some of the slop out of the rack and pinion by forcing the pinion gear down into the rack. I cannot find anything about this kit in my Google searches. Can anyone help me find this kit?
We took it out for our first ride and quickly discovered a loud banging noise when we go over bumps. Today we were with a friend who was following and he said the right rear wheel is bouncing freely. Evidently our Yearben shock is bad. So I looked up the Yearben shocks on this forum and see this has been a problem with these shocks. It also appears they are not repairable. If so I just bought myself a white elephant. This has been a nightmare experience for me. Anyone want to buy a Trooper for cheap?
FYI, I took my shocks to "Shock Therapy" in Phoenix to have them rebuilt.  I was informed today that they cannot be rebuilt. One of the parts is welded and another issue is one of the seals/o-rings would get damaged if they tried to replace it. This confirms what was said by one of the regulars in this forum who tried to rebuild these shocks.
So with the shocks not being repairable I have been looking for replacements for the Yearbens. No one sells them individually. You have to buy a set of 4. Not happening. Some forum posters have had success with FOA shocks. Will be looking into this option. Their shocks are slightly longer than the stock Trooper shocks (24" vs. 23") but can be made to work with a limiter strap. FOA sells limiter straps.
I can't get anyone to answer the phone at FOA and they don't reply to my messages. Also I've learned that the FOA shocks are 24.5" long (pin to pin) extended whereas the mounting brackets on the Joyner are 23" pin to pin when the swing arm is at it's lowest point (touching the axle). Thus I cannot install the FOA shocks unless I compress them first. Also I would have to install limiter straps which requires welding. I am not equipped to do these modifications. Another option is to weld on new shock mtg brackets to fit the FOA shocks but again I am not equipped to do that. It would be a big deal to have the modifications done by a shop. I don't believe it is financially justifiable to invest more money than necessary in this vehicle.  Thus it looks like the best option for me is to buy OEM shocks. I can get them locally. I'll run it with the OEM shocks for a year or so then sell it if it doesn't fall apart. I'll lose money on it but not as bad as if I were to buy better shocks.
Now that I have the wheels and shocks removed I can see the oil filter is easily accessible. It looks like you would not be able to access it unless these parts are un-installed.  So I decided now is the time to change the oil and filter.  So I look to see where the oil drain plug is and there is no way to access it through the bash plate underneath. They did not provide a hole to change the oil! I am dumbfounded. There is not enough clearance between the drain plug and plate to do anything. How am I supposed to change the oil in this thing? Just let it dribble out onto the bash plate and let it find it's way out? What a pile.
One more rant I have to make. The seller said the OEM seat belts would come loose when you are riding so he took them out and installed lap belts like in a car.  I wasn't thrilled about that but I didn't give it much thought. After riding in the machine a couple of times I now realize these lap belts are absolutely unsafe in a rollover. You need shoulder harnesses in these machines. I see in the forum this has been an issue with these machines.
A friend gave me a set of racing harnesses but they are too wide for the openings in  the seats. So yeah, now I need to spend more money because of the low quality of these machines.
PS, the owners manual says very clearly the roll cage on these machines are cosmetic. They are not designed to protect you if the machine rolls over.  They don't mention that in the sales brochures. Folks, if you buy Chinese you are literally risking your life!
I have the the same problem with my bash/skid plate.  I think they installed the skid plate, then installed the engine.  They used nuts and bolts to install the skid plate.  I could loosen the bolts but then the nuts started to turn = couldn't remove the skid plate under normal procedures.  What I did is loosened the bolts, then inserted a thin pry bar between the skid plate and the chassis to bind the nut so that is couldn't turn.  I was able to remove all the bolts. I replaced the nuts with metric U-nuts.  They mount on ears attached to the chassis.  The U-nuts won't turn.
As for accessing the drain plug, I'm going to drill a large hole so as to access the drain plug.
Roll cages need diagonal supports.  There are other rides that have the same issue.
I can't speak of the Trooper, but my oil filter is easily accessible via raising the bed.  Your Trooper and my Renegade have the same engine now (as of 2014).  I have a concern about oil pressure at idle.  It's barely the limit of 10 psi at 1,000 RPM.  The common standard is 10 psi per 1,000 RPM.  I use 50 weigtht oil and that helps the idle oil pressure.  Above idle the oil pressure is fine.
I agree with the racing harness.  Can't easily access the storage compartment under the passenger seat.  Buckles too wide.  I bought my ride used off Craigslist.  The previous owner took out the 5-point harness and installed lap belts, too,  I reinstalled the harness and haven't had problems with them coming loose at the attach points or the buckle, not yet.
Working on the wiring is nearly impossible if I want to add electrical accessories.
My ride has an OBDII connector but is isn't a standard protocol.  My OBDII testers can't communicate with my machine.
I like my ride.  I don't have $20k, $30k, $40k for a fancy ride.  It's more of a utility/farm vehicle and not so much a sport vehicle.  It's just with Joyner, you may have to be your own mechanic as I've learned.  As with most advertising for almost anything, they put flowery words promoting the advantages of their products and not mention any negatives.
Thanks for your feedback Dan. At least I know others have the same issues. Looks like I'll be dealing with the bash plate now too. I don't have a cutting torch so I'll have to drill a bunch of little holes to make a big one. That will require laying under it with drill oil and shavings falling on my face for an hour. I might consider pulling the plate if it isn't too big a deal. I wonder how the previous owner dealt with it. Maybe he never changed the oil. This machine has 4000 miles and the oil is pretty black. I would not be surprised. I can't ask him though because he knows that I know he cheated me by not telling me about the bad shock.
Try to remove the skid plate the same way I did and replace the nuts with U-nuts.  Mark the location of the drain hole before removing, of course.  Drilled holes in my case seem to migrate from where I drilled them to stay.  When I remove my skid plate for my next oil change, I'm going to drill a BIG hole so that it can't migrate too far. (:<))
I drilled a 3.5" hole with a hole saw. I can get my hand through. I already had to use it after overfilling the oil. It is important to get your hand in because the drain plug is at an angle so not easy to thread it using a socket. I installed the clip nuts like you did but I couldn't use them on the 2 rear holes since they wouldn't align with the holes on the plate. At least I won't have to remove it any more.
Good job!  I had trouble with the rear U-nuts,too.  I just forced the fit.  I think their precision in welding the ears misses the point where they should be attached.
  • 4 weeks later...
Update: I have been experiencing a problem where the engine will suddenly start lagging like it is not getting fuel. It will sputter and stall when giving throttle and cannot be driven when it is doing this. At first it seemed to happen when it was hot.
I took it to a local auto repair shop and they ran several tests while it was acting up. They started looking at the ignition and thought it was bad spark wires or a coil.  Then they put a pressure gauge on the fuel line on the input to the fuel injector rail and found it was inconsistent, so they recommended I replace the fuel pump, filters and pressure regulator. The fuel pressure regulator gauge is constant at around 7 (=70 psi?).
I went ahead and installed a new fuel pump and it seemed to run well, so I figured it was fixed. However today the behavior happened again. I was not doing anything to stress the engine and it was not hot. I noticed the oil pressure warning light had come on when it happened. The oil pressure gauge is always at the very low end when it is running, ever since I got the machine. I originally assumed the sender unit was not working properly, but after running the machine a few times it seems to be giving consistent readings.
Now I am wondering if the engine has problems. The oil was very black when I got it and when I changed it there was a lot of metal on the drain plug. I don't know if there is some sort of safety mechanism that puts the engine in Limp Mode when the oil pressure is low.
At this point I am clueless as to how to solve this problem. It seems the auto shop doesn't know what to do either. There are too many unknowns. There are unknown issues with the wiring (previous owner says the fuse block is corroded). I don't know the history of the vehicle, i.e. how has it been maintained and what the default oil pressure should be. I don't know the intricacies of the electrical/mechanical system and I don't know the common defects. I am hoping there are others who have experienced this and have an answer.
One more thing to note: the previous owner installed an auxiliary fuel tank under the front cowling. It is connected to the the main fuel tank via a hose and T fitting on top. This T fitting is the one that originally connected the bypass fuel line from pressure regulator. He disconnected the bypass line and plugged it so as to use the T for the auxiliary tank connection. This may be the cause of the problem, but I doubt it since he would have experienced problems from the time he set it up and would have addressed it then.
Quote
Problem solved. It turned out to be a failing toggle switch for the fuel pump (the previous owner installed a toggle due to a corroded fuse box). I had the behavior today and stopped as usual to let it reset. When I flipped the switch to start the pump, nothing happened. This is the first time it did this. Now I knew it was the switch. Put in a new one and everything is good. The reason the oil pressure light was coming on is the engine was starving for fuel which caused the idle speed to be too low to generate enough pressure to be at operating range. In hindsight this was not related to common problems with these machines so it probably won't help anyone, but fortunately it was not a serious issue.
I ran some tests. I have spark (got bit holding the plug wire to the coil). I have fuel (gas spews out of the hose at the injector rail). I know I have compression (auto shop checked that). Only thing that comes to mind is the injectors are not letting the fuel into the engine. That could mean a bad ECU. I ordered a new ECU from china. It will take a few weeks to arrive. It is cheaper throw parts at it than paying a shop to run tests (ecu plus shipping is $112). Also ordered an O2 sensor for about $20.
I would check both of the fuse blocks, dirt can get in the contacts of the fuses and cause problems. Clean them out and make sure they aren’t deformed. Can use small flat blade screwdriver or needle nosed pliers to bend them some.
I use dielectric grease to keep the crud out, but depending on how you wheel the beast, they need attention from time to time.
I haven’t had problems with the plastic (molex style) in-line connections of the wiring harness, but I did clean them and apply grease when I bought it years ago.
i'll have a look and post back if it helps. thanks.
  • 4 weeks later...
Still can't figure out what is wrong. I've recently replaced the ECU and the IAT/MAP sensor but the problem persists (I have also ordered a CO2 sensor but it hasn't arrived yet).  I've replaced the fuel pump and have tested the pressure and checked the injectors so I know it is not a fuel issue. I know it has spark. I know it has air (bypassed the air filter). I know it has compression (tested). When it runs it runs fine so I know all the fundamentals are there. My only conclusion is it is a bad sensor or a bad wire.
The last time I drove it the speedometer gauge started jumping erratically as I drove. There were no other symptoms in the machine as I drove so I decided I would deal with it later and ignored it. After an hour or so of driving is suddenly just crapped out on a road. I got it to fire up a couple of times and had to give it throttle to keep it going but then it would sputter and die. Eventually I could not get it started at all so I towed it home. I let it sit overnight and tried again the next day and still no go. That is when I decided it would be cheaper to  start replacing parts to eliminate as many possibilities as practical. After sitting for a week or so the machine started again but I have to give it throttle to get it started. Once it starts it runs rough and wants to stall when I give it throttle. After a few seconds of coaxing it to stay running it settles down and behaves normally. At first the speed gauge acts erratic as before, but after the engine stabilizes it drops to zero and stays there, though it still jumps every so often. I want to believe the speed gauge symptom is related but in the past the gauge was fine when the machine would act up.
I've studied the EFI system in the manual and I see there are ways to test all the sensors, but in some cases it requires inserting a meter into the wiring system at the ECU. I don't have a means to do that. Also I cannot find a diagnostic port in the wiring system so there is no way to run diagnostics.
I am at a point where I have to tow it to a local shop and pay them to see if they can figure it out, which without a diagnostic port and lack of familiarity with these machines I suspect is going to be futile. I could order all the rest of the sensors from China and wait another month or so to get them and replace all the sensors and see if that solves it. If that fails then I am left with replacing the wire harnesses which I am not able to do. That will be a very expensive solution if I have buy the harnesses and to pay a shop to install them. The final option is to just sell it as a mechanic special and take a huge loss.
54 minutes ago, mixfixdave said:
Have you tried swapping the engine, fuel pump and fan relays...may help eliminate a bad relay?
I am wondering about the fuel pump relay. The previous owner bypassed the pump and fan relays and hotwired them to toggle switches. This was because he had problems with corrosion in the  fuse box. In my review of the ECU and injector system I see the injectors are wired to the pump relay. I don't understand why. I don't know if there is a way to test the relay or the circuit. Any ideas?
PS, I am getting good pressure at the injector rail so I know the pump and pressure regulator are doing their jobs.
    • By camojay
    • By mhill
      Any thoughts? Suggestions?
      Thanks so much
    • By staind
      thanks Dan D. aka staind
    • By GaryC
    • By lowgear52
