Does anyone know the gear ratios of the Trans & Diffs? If not and you have to have work, get the ratios or number of teeth on the gears. If I have to replace the engine someday it will be will something with more POWER so I/you will need the gear rations. Worst case would to be travel to the shop in Phoenix.
rocmoc n AZ/Mexico
Rocmoc, i think the gear ratio is 286,s I read it some wear but don,t remember. I know it is high, we are getting our low gearing through the tranny, it must be under driven.
Hi Flatbed,
That is my concern finding tranny gearing low enough for the stock diffs. May have to find a replacement diff if I ever want to go to a different engine & trans. I really would like more power but do not want to go to a turbo. When ya think we will see aftermarket motor parts at the local speed shop. LOL! The HP produced by Honda, Toy & Subaru is outstanding now days. We leave Sunday but will have the laptop with us. See ya in Jan.
rocmoc n AZ/Mexico
Rocmoc, i think there is more power in the intake system. The intake manifold is what you would use for a high reving engine, plus the you know the throutle body could be bigger, and than you have the long distance the air has to flow in the aircleaner system. Build a new intake plentem with the trottle body up on top, you can put the air cleaner next to it, i think we would pick up alot of bottom-end. I would not think these engines run this way when they are in the cars in china. I don't want a turbo either, break to many parts, but it would be nice to get 25 more hp on the bottom end.
rocmoc n AZ/Mexico
Rocmoc, The gear ratio for the differentials is:
Ring Gear 32 teeth
Pinion Gear 15 teeth
Gear Ratio 2.13
I dont know what the trans ratio is.
  flatbed said:
Latch 73 Have you had any luck finding a ring gear for the trooper, i know you where looking for info on other sites, jusst wondering if you came up with anything.
Yes, There is a Joyner dealer in Idhao that had a rear diff. housing somehow break but the gears are good. He called Joyner and had them do a breakdown cost on new comp. diff and he said that a new set of gears would run $350.00 so he offered me his used set for $200.00
    • By CapnWalleye
    • By aefron88
    • By SSgt1994
      Myron
    • By A P
