HI All,
I have an 800cc Hisun fuel injected twin cylinder. Im trying to diagnose a no spark issue.  I had a bad crank sensor, replaced that and still got no spark and yes i doubled check the new one to make sure it was good.  Checked the both coil packs and they are both receiving power, also checked the resistance and both seem to be good.  It seems to me like the ECU is not sending the signal to the Coil packs.  Anyone have any idea how to test the ECU?  Any help or advice would be appreciated.  Thanks
It has two coil packs, one for each cylinder and a crank position sensor.  I have already replaced the crank position sensor and double checked the ohm readings.  I have also checked the Coil packs and they both have identical resistance readings.  I cannot find a value for the coil packs but since they both read identically I'm leaning tword them being ok.  I also have 12v to the wires connecting to them.
  • 1 year later...
Have you checked all the fuses, or relay, specifically the one that provides power to the coils?
If all is good there, and you've replaced the crank position sensor. That doesn't leave much in a no spark condition, except for the CPU.
I checked wires going to coil, I get 12 volts on one of the wires  when I turn the ignition on . Checked all fuses, dont know if there is anyway to check all the relays. I'm ordering new cpu today.
Does the vehicle have more than one relay? On most cars, if there's more than one, you can interchange them from a known working circuit.
It's been a few years, but I'm pretty sure that they can be tested fairly easily. I've always had good luck using the above method for diagnosis.
I'd certainly want to eliminate all other possible causes before putting out the money for a new processor.
It does, I switched them around but didn't make a difference.  I'm looking at new ecm fron $80 - $150.  Alot of them say for hisun 800 but have different numbers.
Just wanted to give update . It was the ecm. Put new one on and got spark immediately to front cylinder.  Ran but smoking and no power. I checked back cylinder and no fire. Pulled coil to check with meter and found wire was not getting good connection where it plugs into coil. All good now . She will scream !!!. Next is to figure out why 4x4 switch wont turn.  Thanks for all the imput....
  • Like 4
  • 1 year later...
  • 1 year later...
Laubrey, did you ever get this resolved? I'm having a similar issue and trying to troubleshoot. I've checked pretty much everything, even back-probed the ECU and things look fine, but no spark.
Thanks in advance, Dave
    • By Frank in MI
      Thanks for accepting me!
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By hisun junk
    • By Justine
    • By Poppateets
