By Kingfish
By Robby
By MISTERTIRE66
Recently inherited 08 joyner renegade r4 800.. seems to be sound mechanically but I cannot find bal joints. Any pone help with other replacement part number please.
By Hugh
Cooling fans are working, I can hear it running once awhile if I can get the engine warm up enough. Thank you for all the help.
Hugh
By Grizz
hello grizz again I keep blowing this fuse left side on bottom it’s a 15 amp I have checked all the wires can’t find anything bare or broken it is a 2021 axis 700 I put a 20 amp in so I could pull out of shop to take pictures. Does anyone have any suggestions. Thanks.
