HELP - my wife and i just bought a 2013 joyner trooper 1100 and we rode for 2 evenings with no problems. Went to ride last night and all of a sudden it acted like something was catching up and it didn't want to move easily. Whatever it was must've broke and now it moves with no problem but is making a rubbing/grinding noise somewhere in the backend. Could it be wheel bearing, differential, or something in cv shaft. Any info or similar experiences is appreciated.
Short answer to your question about possible issues:  Yes.
Impossible to troubleshoot from a distance.  I would look at everything from the transmission output shaft to the wheel bearings.
Maybe put it up on jacks and listen to where the sound is coming from.
On 9/20/2020 at 6:03 AM, David Mcmillian said:
Has anyone found a replacement for Joyner Sand spider 650 cc outer cv axles ?
Welcome to the forum! For maximum exposure, and to observe forum courtesy, and tradition. You should open a new topic in the Joyner sub section.
Any luck with this problem yet?
    • By camojay
    • By downseast
      Hi everyone
    • By staind
      thanks Dan D. aka staind
    • By SayHiToRambo
      08 trooper 1100
      thanks!
