I have a new Massimo T boss 410 with 2 hours on it. I tried to start it today and I get no power at all. I tried jumping it and still no power sounds electrical problem. Any help would be great
Mine did the same thing once. Put the key in and tried to crank it over. I got nothing. Removed the battery and put it on a charger. While I was at it, I found that the cables at the battery were not very well secured, so once I got a full charge on the battery, I reinstalled it and was sure to get a tight fit on the cables. It's been good ever since. It does lose a bit of a charge if it sits too long without being started.
  • 1 year later...
  • 8 months later...
    • By CapnWalleye
    • By ToughLuck
    • By Joe Breaux
