Kubota RTV 500
By GBarney
Recently bought a 2010 RTV 1100 with bad engine. a d1105T out of a toro 5400 just came available locally. Looking for info on if anybody has installed the turbo version of this engine, what challenges/ problems were encountered, how it turned out.
By Hunterman22
By Duane Baker
By aefron88
