massimo buck 400 Fault Code Troubleshooting "How To"
By Xov
By redneckred
Can anyone tell me how to get the engine codes to display on a 2012 Bennche Bighorn 700X? I played with the gauges once and lucked up on this but can't remember what I did. Will the codes automatically display if there is a code or do you have to cycle through the display?
By Mark Anderhalt
By Gary T
By felo72
