2012 4010 mule trans
By Frank in MI
Thanks for accepting me!
By Poppateets
By Greg Kilgore
Plumbing parts list.
2 1" x 3/4" x 1" PEX Tee
1 3/4" PEX ball valve
1 1" PEX ball valve
Wide view of the plumbing.
Kilgore.
By Eagle Mountain Outfitters
By Hunterman22
